Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 103TDI turbo whistle
    Jan 2008
    Sunshine Coast
    Leaking is also normal, and new o-rings donlt do anything as the connection is poor to start with, even the Porsche's suffer from it. You can simply ignore it, as it;s no big deal, but if like me you want that last kw, then undo the clip ( note how and where it sits as you have to get it exactly right to save dropping a hose on the road ) clean up the connections with some degreaser and prepsol / metho etc, and silastic them together.
    Afraid other than that, you will have to live with it. Point it out next service, maybe they have a dealer fix too.
    Bowral, NSW
    I had the clamp come loose off the exhaust outlet of the turbo whilst at a track day in Brisbane.
    Quick trip to Jmac's workshop and a new bolt fixed it straight away.
    Sounded great though!
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Feb 2014
    Central Vic
    Quote Originally Posted by Mysticality View Post
    Why can't you buy a 'bug' that transmits on a car radio frequency the sound of the exhaust at the outlet?
    Gosford Central Coast NSW
    Quote Originally Posted by Greg Roles View Post
    My trick is to pull it apart like greg has said, clean it, and then lube the o ring with petroleum jelly. It will swell a bit once you put it back together (takes hours) and might seal better (for a while).
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
