![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
davidno64
Well now at 60,000 plus Km's, I have not had any more starting issues. But I did have what I thought was a bettery issue.
Vw could not fault it, so I replace it (the battery) and all Ok. But they had also changed the MAF loom to adress some issues.
Still remaining unresolved was an intermitant loss of power, seldom occours but potentially dangerous in traffic.
NOW, recently I copped a red light camera. Why, the bloody cars got worse intermitant and more frequent, also sometimes
very severe power loss. I got caught mid intersection with no power and stationary. Then delayed, the revs rose and the car
was drivable again. Normally after acelertion, then braking. Either I get a delayed throttle reponse or no throttle response
at all. Sometimes when taking certain roundabouts, either a delayed throttle response or no throttle response at all.
Took it to VW, they had if for 3 days and could only partly replicate the fault and only under the driving conditions
I reported to them. No fault codes, no total power loss. But certainly a part power loss/ delayed throttle response.
Picked up the car, partly repaired. They had found an air leak on the EGR and recitifyed it. It does seem a bit better.
The car gets returned to VW in a few days again to further diagnose the fault. As they can not identify the cause and
have not complitly fixed the issues.
I suspect this is an injection problem. Weather it be a physical issue the the injectors themselfs or the control to
them, an interupted signal. Anyway when I have an answer, I will post any updates but has anyone else had simlar
Power loss/Power delivery issues (specifically relating to the injectors).
