My aim is to get an answer on refurbishment of injectors from the UK. If this is indeed really the case, then the problem isn't quite so scary. Most TDI's will be towards or into extended warranty now, and that only gives you a year or two more, so we need a solution to this problem. If this is indeed a possibility I will look into the loom on my own car, and investigate the possibility of a silicon insulated upgrade. I'm not venturing in there until there is a backup plan in place, no sense tempting fate!
