Page 9 of 38 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 372
Thread: 103kW/125kw TDI PD Piezo Siemens injector failure thread
  1. #81
    Adelaide hills, SA
    Quote Originally Posted by kaanage View Post
    So if the new CR injectors are also actuated using piezo electric crystal stacks, does that mean all the new high pressure CR engines are also prone to this failure mode?
    It is unlikely, since the CR injectors and their wiring aren't surrounded by hot and dirty engine oil, but for confirmation of that, you have to wait little bit longer.
  2. #82
    Jun 2008
    South Coast N.S.W.
    Mines been missing a bit every now and then, it has also on occasions been very jerky when I actually switch the engine off (feels a little bit like it's running on) it did this the other day and has been OK since. All this talk of these injectors failing is making me wonder if this is what happened to mine when I first took delivery in 2008, I made mention of what happened in an earlier post and put it down to a cold engine DPF Regen, just wondering now if it could have been an injector issue. Mine is out of warranty in September this year, I think the extended new car warranty will be a definite consideration as it would more than pay for itself in the event of injector failure. I totally agree with others that there should be a recall especially when engine failure in traffic could be life threatening. I'd be interested to hear comments from others as to what symptoms they had experienced prior to their injectors failing.
    Russ
    2005 Subaru Outback 3.0 R Premium
  3. #83
    Jan 2008
    Sunshine Coast
    My vote Russ is oil sludge gumming up your flap mechanism whose job it is to stop airflow for a smoother engine stop. That same sludge causes hesitation problems when the nearby EGR valve can't operate correctly, especially at speed when you plant it.
    Have you ever cleaned it out mate?
  4. #84
    Jun 2008
    South Coast N.S.W.
    Quote Originally Posted by Greg Roles View Post
    Hey Greg, it hasn't had any issue with hesitation when I plant it, it still pins you to the seat on acceleration and is very responsive at speed when you put your foot down. Other than checking oil and fluids I haven't laid a spanner on the engine, I took one look under the bonnet of this beasty and decided I'd leave it alone, I still like to get adventurous under the bed sheets but not under the bonnet of a car (not the late model ones at least) Is this something the dealer would know about and fix under warranty or will I have to get my hands dirty? I'm guessing there is already a thread on it here somewhere ? The part that pi$$es me off is that I bought a diesel for reliability and although it hasn't let me down yet (fingers crossed) it would appear that there is a strong possibility it's going to at some stage, whether it be injectors, DPF or some other glitch. I can't imagine not having this car as I love it, but it's annoying to think that VW must be aware of these issues and does nothing about it until people start complaining
    Russ
  5. #85
    Adelaide hills, SA
    If you look under the car at the 2 hoses attached to the intercooler, they are most likely wet from the oil and you may even see the oil drop at the connection. It's like that one every Golf TDI I see and our MK5 in no exemption. Throttle body needs to be cleaned otherwise it will cost much more when the flap fails.
  6. #86
    Apr 2008
    Sad news everyone.
    My GT Sport failed last Friday. It had been stuttering here and there in the weeks leading up to it.
    The dealer just told me that they are replacing all four injectors.
    The odometer is 100,256 so my extended warranty is kicking in. SO happy I bought it.
    Does anyone know if they are putting the same old injectors that are prone to fail in there if there is a revised version that's better?
    Will post again when I know more.
  7. #87
    Oct 2010
    Melbourne, VIC
    I spoke to someone today who has a Passat 125kW TDi and he had 2 injectors fail and then replaced a few weeks ago and then the other 2 injectors fail and replaced this week. I told him to make sure the loom was replaced along with the injectors and he was told that they were.
    He also asked why all 4 injectors didn't get replaced with the initial failures and he was told that his dealer tried but the company which underwrites the extended VW warranty only authorised the replacement of the failed injectors.
  8. #88
    Jan 2008
    Sunshine Coast
    Am heavily researching this and will post good things I come across. At least this site suggests that the replaced injectors and loom are different, upgraded models. A fair bit cheaper in the UK too.
    UKpassats.co.uk • View topic - 2.0 TDI Injector Upgrade
  9. #89
    Mar 2011
    Traralgon
    2006 Passat 103kw TDI DSG wagon failed at 4 years and 150,500 km.
    My 2006 Passat 103kw TDI DSG wagon failed last week, March 2011. It was purchased new March 2007 in Morwell Australia. Its just 4 years old, in immaculate condition with 150,500km on the clock. It has been fully serviced by VW, on time every time.
    Problems started months ago with a stutter or misfire at very low speed. This was minor and I was about to report it with the 150,000km service.
    Engine just stopped when it had been cruising at 100 kph for about 15 minutes. An engine fault alarm was displayed and glow plug light flashed continuously. Turned ignition off and restarted. Engine started with no alarms and drove for further 45 minutes. Engine was turned off and would not start again. Contacted VW and car was towed away. It was already booked in for its service at local Morwell VW dealer.
    Morwell service guy contacted VW and negotiated 70% warranty 30% owner cost split for repair covering labour and materials but exclude towing cost. This seems fair given age and km’s travelled plus outside of warranty. However my expectation is that injectors should last for life of the car say 600,000 km. I note that injector are not listed as a service item in the first 300,000 km
    Costs of repair including GST totaled $4,579. This was made up of Labour of $352 and Materials of $4,227. Materials were 4 injectors, 1 harness and 8 head bolts. Of this my 30% share cost $1,374 plus towing cost.
    In summary things sometimes go wrong in the real world. VW did come to the party with repair cost. It also cost me and having paid once I don’t want to be hit again by accelerated depreciation when I come to sell the car. VW therefore need to solve this before it damages its reputation.
    Thanks to all for the information on this site. Don61.
  10. #90
    Jan 2008
    Sunshine Coast
    I've found the guys in the UK are thinking it is the loom rather than the injector itself that shorts...but seems no-one is still sure what is going on. They are having the same sort of failures we are, cars dropping left and right.
    Have a few leads on refurbishers, but still awaiting an actual email response!! I'm hanging onto this like a pit bull - mainly because as of April I have no more warranty!!
