Page 15 of 38 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 372
Thread: 103kW/125kw TDI PD Piezo Siemens injector failure thread
  1. #141
    Oct 2010
    Quote Originally Posted by Greg Roles View Post
    Affects ONLY the PD170 BMN engine in the VW range, but also the PD 3.0 TDI in Audi from what I am reading, plus potentially the same item used in some BMW and Merc cars 2006-2009.
    Seems to be a lot more engines than the BMN, http://www.vwwatercooled.org.au/f28/...r-55060-2.html
    Also you named the thread "103/125kW".. what am I missing here.. confused.
    Golf GT Sport TDI
  2. #142
    Adelaide hills, SA
    Quote Originally Posted by jazd View Post
    ...what are you confused about? If, you have more informations, then share it with us, please. No need to get confused.
  3. #143
    Jan 2008
    Sunshine Coast
    Mate when I started this thread I had no idea as to exactly what was affected, nor did anyone worldwide really, it's all been a recent awareness to the general public. Transporter feel free to ammend title to just 125kw PD170.
    103kw injectors do fail as well, but rarely, and generally not due to design flaws like the 125kw ones.
  4. #144
    GEELONG
    GREAT to hear, good result. Still seems to be luck of the draw.
    I have the revised loom coming from the UK thanks to my brother over there, and will fit it and do a writeup of the old loom and what I find. Hopefully it will keep my own injectors running a bit longer than they would have otherwise!
    Hi Guys................just found this thread and looked up my vehicle data in the service schedule of my 2008 GTD and it states......GOLF 2,0 GT 125KW FTDI D6F. BMN- KMW LA7W-------- RT, so does that put mine on the danger list?
  5. #145
    Adelaide hills, SA
    I think we leave the title as is, for now.
  6. #146
    Oct 2010
    So it is only the BMN that has this issue? There seems to be a lot of Passats with the 125kW engine in that thread I posted that have failed injectors, but thats the BMR engine.
    Golf GT Sport TDI
  7. #147
    Jan 2008
    Sunshine Coast
    All varients of the PD 125kw engine. For the Passat/Golf it would include the BMN/BMR. I only have all the documents for the Golf.
    Fraid so double cab.
  8. #148
    Jun 2006
    Orange NSW
    Probably the new Caddy 2.0TDI, too. From what my mate "in the know" reckons..
  9. #149
    Feb 2010
    Bexley, NSW
    My engine code is BKP and I had two injectors fail and got all 4 replaced. See post #114 in this thread.
    I've also put my details into the All PD Piezo Injector Failure Register on this forum.
    Engine codes listed in the register so far are BMR, BMN, BKP, and quite a few unknowns.
  10. #150
    Adelaide hills, SA
    ... and some who complained, didn't bother to register, so there is few more that could be in that thread.
