Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 121 to 130 of 133
Thread: The 1.9L PD TDI powerquest
  1. #121
    Oct 2010
    Melbourne, VIC
    bump
    Resident grumpy old fart
  2. #122
    Gosford Central Coast NSW
    indeed.
    Took me ages to finally log with the new turbo and send data to Viezu. I am currently waiting for the new map
    I can also say - make sure you replace or clean your pro-vent filter periodically, as when it blocks up it makes your lovely VW TDI blow oil smoke at takeoff just like a ****ty mitsubishi.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  3. #123
    Got my new tunes!
    Might try and load the new vPerf tonight!
    Woo!
    '99 A4 Quattro 1.8T
  4. #124
    Have loaded vPerf map and driven about 120km on it so far.
    Smoke is down.... well pretty much non-existent.
    Low end torque (belows 2500) about the same
    Top end - MUCH better
    Economy - stupidly good. 5.0l/100 on the way to work (normally 5.1-5.2) and 4.2l/100km on the way home (normally 4.5ish).
    Who wants a Video?
    '99 A4 Quattro 1.8T
  5. #125
    Oct 2010
    Melbourne, VIC
    What I'd like to see are the boost logs.
    Are those mileage figures from the MFD? I've found that mine will change vs actual (from odometer vs fill amounts) with different maps
  6. #126
    Bowral, NSW
    Video video!!!
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  7. #127
    Quote Originally Posted by kaanage View Post
    Guilty as charged. Like I said, I;ve only gone 120km... well 170 now
    I will hopefully do a couple of logs and perhaps take a vid this afternoon.
    '99 A4 Quattro 1.8T
  8. #128
    not ideal logging conditions, but I did it just for you Greg
    same excuse with the video - just for you mysticality - no idea what it sounds like yet!
    http://www.youtube.com/watch?v=Mym-o...ature=youtu.be
    '99 A4 Quattro 1.8T
  9. #129
    Oct 2010
    Melbourne, VIC
    Looks like you've boosted your boost by 10% - I'm guessing the extra air is burning your fuel more completely => less smoke.
  10. #130
    Actually thats something I cant figure out. With the old turbo I was seeing the actual boost line match the spec very well. With the new turbo, the actual is over - why?
    More diagnosis this weekend hopefully.
    My vid tells me i can do 40-100 in 7 seconds, in 3rd gear. I love diesel
    '99 A4 Quattro 1.8T
