Here's a great pic by a TDiClub member
gldgti, you should spin off a thread about this so it can be stickied for watercooled members usage.
Gigitt, I never read anything at TDiClub about using the BoostValve INSTEAD of the N75 on VNTs - that seems reckless. Or was it only being used this way on the wastegated TDi's. The issues I read about were to do with the valve not closing off soon enough once the vanes closed but gldgti doesn't have that issue at all from the log he has posted (maybe it develops over time as the valves gets dirty)
Resident grumpy old fart
