Originally Posted by
Evaded Motorsport
VNT15 and KP39 are basically the same (sits in the same place, same ports etc, same performance). Depending on where you are in the world and which model you purchased depended on whether you got the VNT15 or the KP39. The KP39 tends to be more reliable than the VNT-15.
Going back to some of the initial conversation, it seems from the top post on this page at TDI Club, that the Europeans and North Americans think the KP39 is rather less reliable than the VNT-15 as Borg Warner have used lighter construction to reduce the inertia for quicker spool. The preceding page has a nice pic of one that destructed with a tuned engine.
It may be a very good thing that you have the VNT-1749VB ready to bolt on, gldgti.
Resident grumpy old fart
