Page 6 of 14 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 133
Thread: The 1.9L PD TDI powerquest
  1. #51
    Gosford Central Coast NSW
    I dont think rpm is any issue. The main danger is lots of boost and fuel at very low rpm (like if you are hitting 30-35psi at or below 2000rpm)
    to give you an idea of the rod strength for rpm - I've seen video of a guy re3vving a 1.9D (like the cabby's engine) out to 7000rpm on a drag racing setup.... tdi rods
    never get those rpms out of a tdi though - you need IDI for that
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  2. #52
    Oct 2010
    Melbourne, VIC
    I read somewhere that 300 bhp was the limit for our rods so with my plans, I'll be safe
    Resident grumpy old fart
  3. #53
    Yeah, easy I reckon.
    Its not the hp that kills tdi rods, its the massive torques (you see them bent like bananas)!
    '99 A4 Quattro 1.8T
  4. #54
    Oct 2010
    Melbourne, VIC
  5. #55
    Thinking exhaust pretty soon.... Was crawling around under the Skoda the other day, and theres just soo much room under there (since the body is ready for 4-mo system if required) that I thought... why not go 3" just for fun
    '99 A4 Quattro 1.8T
  6. #56
    Jun 2007
    Eastern Suburbs Melbourne
    I ...I've seen video of a guy re3vving a 1.9D (like the cabby's engine) out to 7000rpm on a drag racing setup.... tdi rods ...
    This, I have to see!
    Sounds like a plan! Not afraid that 3" is a touch large? Compressor outlet is probably only 2" no?
    i like volkswagens
  7. #57
    turbo outlet is not even 2".... but doesnt matter really. I still have a bunch of 2.5" flanges and a couple of bends, so I might make the downpipe 2.5" and the rest 3". I dont think it would be too large - with turbo-diesels the general consensus is that you can't go too big
    I will try to find the video later and post it
    '99 A4 Quattro 1.8T
  8. #58
    ordered more exhausty bits (flanges etc) today from laser cutters in 2.5"... can't be bothered with the 3"
    Also ordered myself some 1.9 PD intake flanges so I can make up an egr valve replacement/race pipe in stainless. I've ordered 4 flanges so if anyone wants a custom race pipe, nows your chance
    '99 A4 Quattro 1.8T
  9. #59
    Oct 2010
    Melbourne, VIC
    If no one else puts their hand up....
    Are you running a catch can yet?
  10. #60
    I have had a provent on it since I got it pretty much
    Once I've made and fitted up my egr delete pipe I'll take some photo's for you Greg.
    '99 A4 Quattro 1.8T
