Results 1 to 8 of 8
Thread: 1.5 head bolts torque specs?
    Jul 2005
    Yarra Junction, Melbourne.
    just about to put the head back on my diesel, can anyone tell me the torque specs? I've got a bentley manual but it only cover petrol models.
    thanks
    steve
    Hi,
    I've got a Haynes diesel Golf manual and it says stage 1 is 7.5 kgfm, and then stage 2 is another 1/4 turn to each bolt. It also says DON'T retorque after 1600km. This is for the 1.5 litre motor.
    imported_brackie Guest
    Bentley
    The Bentley says 90Nm and 66ft.lbs. Procedure:
    "Torque head bolts to 50Nm (37ft.lb). Go over the sequence a second time, torquing the bolts to 70Nm (52ft.lbs), and then a third time torquing the bolts to 90Nm (66ft.lbs)"
    Straight from 'The Bible'. The 1.5 doesn't have "stretch" bolts so the procedure is simple. The Bentley makes no mention of re-torquing after a given milage or period.
    Jul 2005
    thank guys,
    can't wait to get it on the road, I drive 50k's to work, my Syncro is a little heavy on the juice and I don't like racking up too many k's on it and my other car is a '79 bmw 323i 5speed and it is only a matter of time before I get busted speeding in it. :twisted:
    Interesting that two different manuals give different proceedures! Converting kgfm to Nm means multiplying by 9.81, so in Nm the Haynes stage 1 is 74Nm, then an additional 1/4 turn, so the end result is about the same as the Bentley manual.
    I had the head off in my 1980 1.5 GLD back in 1991, and these are the numbers I used. The head gasket hasn't leaked in 14 years, so I guess this torque has been OK!
    I've also had a 1985 GTD turbo diesel with the stretch bolts, with these the tensioning is much less forgiving that the non-stretch type. When I replaced the head on this car a couple of the old bolts snapped while removing them. They snapped just below the surface of the head - what a pain!
    By the way, what have you had to do to your car?
    Stretch bolts
    The Audi 100 diesel that I had (RIP....What a shame!) needed stretch bolts. It was an '81 model privately imported from NZ. I got the new bolts from Canada, and the head gasket too. Had to buy a 12pt in-head socket to do the job. Just as an aside, it really pi**es me off that we don't get fine cars like that in Oz.
    Camden, Sydney
    does it? you haven`t mentioned it before
    Sorry.....
    Stuck record, Mate. But, yeah.....
Similar Threads
  1. 8v head build up
    By static1800 in forum Mk2 Golf & Jetta
    Last Post: 05-03-2007, 09:16 AM
  2. Front engine carrier to body bolt torque
    By aussieg60 in forum Mk2 Golf & Jetta
    Last Post: 14-10-2006, 09:57 AM
  3. torque, 2.0L head
    By deemoE36 in forum Mk3 Golf & Vento
    Last Post: 29-09-2006, 12:45 AM
  4. Torque Ratings
    By golf3 in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 29-07-2006, 06:49 AM
  5. Head gaskets and rings
    By hiho in forum Diesels
    Last Post: 05-05-2006, 07:04 AM
