Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 1.5 diesel questions
    syncro Guest
    Quote Originally Posted by posscakes
    it called a mann made in germany. but what for???
    Mann should be OK.
    May 2006
    Padstow 2211 Sydney
    Oh thats cool, you may need it by the sounds of it!
    I haven't taken the head off yet, I'm planning to drop by the loon and borrow a spline tool to take off the head, I have taken off the rocker cover, and if the gasket isn't the problem I hope to get a different engine, but I won't know till tomorrow when i open it.
    p.s.(sat 13.01.07 12.43am) not a spline like in the books, the head bolts are hex in this one (when you drain away all the goop)
    alternate energy vw enthusiast....and general crackpot
    Gosford Central Coast NSW
    Quote Originally Posted by brackie
    Are you sure the mechanic used the correct head gasket? This is crucial when refitting a diesel head. The number of notches denotes the thickness. Too few notches = too thin a gasket and so piston(s) could hit the valves.
    FYI - everyone. be very careful when measuring piston projection above the block. do it accurately. also note that sometimes this itself is not enough, and the tolerances in the bearings from the main, big end, gudgeon can add up in one direction so that your piston is lightly tapping the head.
    please, always err on the side of caution. get a thicker head gasket if your not sure.... the lower ocmpression will only be a disadvantage on starting.. and will be better at all other times.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
Similar Threads
  1. Running in a new diesel
    By brackie in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 30-01-2009, 10:29 PM
  2. Petrol or Diesel
    By denilu in forum Mk5 Golf & Jetta
    Last Post: 29-03-2007, 10:33 PM
  3. 1.5 diesel Design paper
    By smithy010 in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 13-01-2007, 06:16 AM
  4. Diesel cooling system
    By smithy010 in forum Diesels
    Last Post: 21-07-2006, 01:17 AM
  5. Diesel blowby and runaway... A temporary solution
    By imported_brackie in forum Diesels
    Last Post: 24-06-2005, 10:00 AM
