Results 1 to 10 of 12
Thread: Will a 245 40 18 tires fit on sports pack 18 wheels
    Sydney,NSW
    I currently have 235 40 18. So will a 245 40 18 tires be ok on the standard 18 inch wheels?
    May 2007
    The Sport Package wheels are "Vicenza" 18x8" alloy wheels.
    Try a site such as; Tire Size Calculator - Tire & Wheel Plus Sizing and see what the outcome is.
    Also maybe contact some of your local tyres shops and see what they say.
    Sydney,NSW
    Thanks. I tried the site but don't understand how it works.
    Anyone done this change??
    Pacific Paradise QLD
    Use this one its pretty easy Put what you have in the left one and what you want in the right one it will tell you all the differences at the bottom Does offset as well
    Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
    Sydney,NSW
    Sorry I dunno what the ET and the other field is.
    All I want is to see if current 235 40 18 Vicenza wheels will fit 245 40 18 on the Vicenza
    Dec 2008
    Sydney/Canberra
    They'll fit, but they won't feel as sharp to drive on, and will probably be prone to edge wear.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Quote Originally Posted by cru22z View Post
    ET is the offset or distance the inner face of the rim sits in relation to the centerline of the wheel Either inside or outside it Plus is further out meaning your wheels have less poke Minus means they stick out further
    Erskineville, NSW
    245/40r18 fit 8"-9.5" rims, so yes they will fit the rims.
    Have you got room for an extra 5mm width inside & outside?
    Have you got room for an extra 3mm diameter?
    How inaccurate is your speedometer at the moment?
    Sydney,NSW
    Thanks guys. So does extra width make any difference?
    245/40/18 will fit no worries on a 18x8
    if itll fit nicely on your passat is another question
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
