Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Wheel Offset?
    Apr 2008
    Wheel Offset?
    Does anyone know what wheel offset the Passat is?
    Looking at going Plus1 up to 19"'s!
    RIP! 2007 Passat 3.2 4Motion Black Sedan | 19"s | AVC-9000 | Audi A3 Sportback 2.0TFSIQ
    I have put replica Audi RS4 19s on my 4Motion wagon. I had the factory sports suspension which is fine, no rubbing, scraping etc. I have since fitted H&R springs and found I had to do a small rear inner bumper mod.
    Jan 2007
    45-50ET I believe, well 45 is on the B5 + B5.5 at least...
    Apr 2008
    Thanks guys.
    Was just able to weasel out of VW Spare Parts Mascot that 2 of the wheels from the accessory catalog have offsets of 44 and 47.
    It looks like 42-48 will be safe.
    VW Australia don't like divulging info do they?!?
    Can someone confirm that wheel diameter does not affect the offset requirements for the car?
    Feb 2008
    Sydney, Australia
    The offset depends on the rim width and to a lesser degree, the tyres fitted.
    The standard 17's are ET47 offset and the factory fitted ET18's are 44 offset. To understand offset can be a little complicated to get your head around unless you can make a mental picture or actually draw out the offsets on paper.
    Here is a good resource:
    http://www.tirerack.com/wheels/tech/...jsp?techid=101
    The factory option 18's are 8" wide and the factory 17's are 7.5" wide, but the 18's come with 235/40's and the 17's with 235/45's. The 17's "bag out" more compared to the 18's tyres by an extra 3-5mm due to the narrower rim.
    The best way to look at offset and rim width is to do a drawing on paper. With the A4 page in landscape orientation, start with a vertical line in the centre of the page, which represents the centre line of the original rim and mark it "centre line". Next draw another vertical line to the right of this line corresponding to the offset of the wheel, so if it is ET44(standard factory 8" rim), draw a vertical line 44mm to the right of the centre line of the rim and mark it "mounting surface". This represents the mounting surface that the wheel bolts to.
    Now, rim width is actually the measured width inside the rim lip where the tyre bead goes, not the outside of the rim lip. The outside of the rim lip for an alloy wheel is 1" wider than the indicated rim width, so an 8" rim is actually 9" wide when measured completely across the rim width edge to edge. So, when drawing the rim width on paper, use the "centre line" and measure from that line the rim width divided by 2 each side of that line. For a 8" rim(9" actual width or 228.6mm) measure 114.3mm each side of the centre line.
    This shows you how the rim fits on the mount face and how the offset affects where the rim sits and how far out it sits.
    If you are going from an ET44 to an ET40, but using the same width rim of 8", then you just measure back towards the centre of the rim from the mount surface 40mm(left of the mount surface) to find the rim centre. You draw a line and mark this as the rim centre of the new rim. From here you then measure the same 114.3mm each side of the new rims "centre line" to obtain where this rim will sit.
    In the case of an ET40 rim being fitted compared to an ET44 original and the same width, then the outer edge of the rim will sit further out by 4mm giving more room inside, but less outside.
    If you are fitting a 8.5" rim(9.5" overall) with the same ET44 offset, then do the above procedure, but measure 120.65mm(241.3mm overall width) each side of centre. The rim will sit outwards by an extra 6.35mm.
    Wheel diameter does not affect offset as long as the tyre fitted is the same overall circuference/diameter as the original, so you will need to fit a 235/35 x 19" to your 19" rim and *try* to use a 8" wide rim with an offset of ET44 - ET50. I would suggest an ET45 would be ok as ET45 is usually common for an aftermarket VW rim and keeps the rim/tyre combo to the "outside" more than ET50. ET40 *may* sit too far outwards and you may get guard issues and over ET50 may mean strut rubbing issues. If you go for a 8.5" rim you may get away with it if you stay with ET44 or ET45 as the tyre width of 235/35 is *about* the same when mounted on a wider rim of 8.5" when compared to 8".
    I hope this helps.
    Jul 2007
    Sydney - the regressing city
    Quote Originally Posted by Golf Houso View Post
    For the B5 and B5.5, the ET should be 35...
    Jan 2007
    Quote Originally Posted by sci_fianime View Post
    Nope ... just checked my B5 Sport 20V from behind the center caps and it said 16x7 ET45 ...
    Apr 2008
    Thanks Lance
    Thanks for the explanation Lance.
    So basically I should stick with an 8.0" rim width so there is some room to play with between the struts and the wheel arch?
    I would like 245's as they are a lot cheaper (due to them being common), and will look a bit better. I think the slight increase in 'rolling circumference' will be negligible, so odometer accuracy will be ok. Also i think the 8" wheel should take it, and if the offset is right the wheel arch rubbing should be ok.
    Whaddayareckon?
    Jan 2008
    Melbun
    just as long as the wheel isnt touching the suspension you're fine. 1mm clearance is all you need. however you'll find that with 245 tyres on an 8" rim, its the tyre that will rub on the suspension not the wheel. however 225 on 8.5 for instance it will be the rim that is at the widest point. 245 on 8" is a little bit balloonish
    2x Caddy, 1x Ducato
    Aug 2006
    225/30/20 is wot u need
