Mine works perfectly BUT with the RCD510...Hi all,
I had the guys at No Limits in South Melbourne install the Kufatec Plus bluetooth unit (R36 with SatNav). I also had the VagCom codes done to activate all steering wheel & cluster display controls.
Generally works ok but there are some bugs & I'm wondering if any one else is experiencing the same & if you know of any fixes (the installer can't help):
1. Every time I get into the car, my phone connects ok & phone book is downloaded fine. BUT it does not updae the recent calls lists (i.e. dialed, answered & missed calls) on the RNS510 screen.
2. I can use the keypad on the RNS510 screen to dial phone numbers BUT that same keypad is inactive when in a call where the recorded voice says "press 1 to talk to a human bla bla bla".
3. When in a call, if I press the 'OK' button on the steering wheel (say, to cancel the speed alert message), it hangs up the call. Pressing the button with the little phone symbol also hangs up the call but that is how the phone button is suppose to work BUT not the 'OK' button.
Thanks!
