Originally Posted by
Lance B
This is really funny. I am not having the difficulty in understanding the difference between approved oil and oil that meets or exceeds the specs, you are.
Actually, you are having difficulty.
Being "approved" does
not make it mandatory, just that this is the oil that VW recommend, but there can be others as long as it meets the spec, it is
not a case of must use, or else. The
only thing that you
must use is the
spec, not the
approval.
VW Approved Oil is mandatory. The Service manual says so. VW publish a list of Approved Oils which is several pages long so it's not like you are locked into a specific brand or have to buy direct from VW.
IIRC, to gain approval requires a submission to VWs oil testing laboratories & payment of a fee (3000Euro?). When Penrite gained Approval for their Eco oil they were fairly keen to show off the letter from VW.
Any oil manufacturer can mix an oil that meets the spec but it will only get VWs stamp if they have paid the fee & got the letter of Approval.
It's got nothing to do with whether "I know better", it's the
law and also that there is no magic oil that VW has approved that makes in invincible against oil related engine failure and also that VW engineers are no better than oil engineers.
Maybe VW are trying to protect their customers from using sub-standard lubricants?
Again, the
law states that they
can use it because the
specs, not
approval, say that it can be used. Also, as I said before, you cannot be made to use a
particular manufacturers consumable, like oil, just as you cannot be made to use a particular
manufacturersfuel.
VW aren't making anyone use a particular consumable. They are asking you to use an Approved oil. The approval process requires a payment & a letter of approval (Certificate of Conformance for want of a better term).
Also, all the manual states is that the oil must be VW 504 00, it says absolutely
nothing about it needing to be Castrol!! So, even the manual states that the oil has only to be VW 504 00, and therefore
any oil that meets
that spec is what can be safely used.
No, it has to be approved. Meeting the spec doesn't cut it.
On the other hand, the R36 may not actually need VW504.00. I haven't seen the manual but in the case of my Skoda, VW504.00 is only needed for cars on QG1 variable service regime, which we don't do in Australia. QG0 & QG2 (fixed servicing) only need VW502.00. In theory, all Australian vehicles are on QG0/QG2 even if they came from the factory on QG1.
I'd be interested to see a scan of the manual (near the same area as checking the oil level) and see what it says.
