Results 1 to 6 of 6
Thread: Water Leak
    Aug 2007
    Thumbs up
    Could be Rad core mate. Pressure tester will find that no dramas. 1.5 bar of pressure is more than enough. While im writing this mate i realise that you must mean left side of engine and not left side of vehicle correct me if im wrong. If thats the case it could be water pump but best way to tell is to pressurise the system champ.
    Alba European
    Aug 2007
    Horningsea Park
    Thats what I meant, left side of the engine.
    How would i go about pressurising the system?
    Luke
    Aircooled & Watercooled Nut
    62 and a Half Bug
    02 Bora V5
    yer luke the water pump sounds like the problem, they can leak from 2 spots
    - around the main casing, just rebuild it with more Blue maxxxxx!
    - from the seal/bush in the pulley shaft, which prolly suggest you have to replace the front of the water pump!
    Aug 2007
    doin just the front of the pump is a waste of time and you have to disturb the cambelt. Do the whole thing and you dont , and change your stat while you are at it mate. Bythe way you pressure the system, with a pressure tester, but yeah sound like it dude.
    Alba European
    Aug 2007
    Horningsea Park
    Thanks Jimmy and NIck
    Ill get on it asap
    Keep u's updated
    Luke
    62 and a Half Bug
    02 Bora V5
