Hi all
The wheels are OZRacing "Vittoria" 18 x 8". Same size as stock. I had the suspension done last year - KW V3's, K&R sway bars and WhiteLine bushes replacing every single bush. I had to roll the guards as I was getting some tyre rub, its mainly fixed it up.
The VWR BBK (with 2 x piece VWR rear slotted discs and labour costs) came it at about $5k - which is about $3k less than the same things from Brembo, except these ones have the VWR logo which I kinda prefer anyway - that and it was a plug 'n play fit too - zero issues with clearances, mounting points misaligning etc... OEM parts fit best!
I recently bought a damaged R36 front grill in carbon fibre. I had that fixed up and fitted now... I think its come up OK. I'm removing the bonnet wrap soon - it was cheaper than a resprayed bonnet at the time (stone chips).
And I've changed every exterior globe to LED apart from the steer-assist one, for some reason that socket hates LED's CANBUS or not, makes no difference!
Anyway, pix tell a part of the story! So, heres a couple...
Rgd's
AT
