Electronic Park Brake Fault
Hey Guys,
Having trouble with intermittent Hand brake faults. About 1 in 10 times I get in the car and turn on the ignition and before I touch anyting I get a " Hand Brake Failure , See owners manual" on the MFD.
If I press the handbrade button the handbrake will not release. The only way I can get the handbrake off is to remove the key completely and then turn back on. Most times everything is working fine again. I have also had it where, after pulling up and to park I get the same message and I can't get the hand brake ON. Solution is the same by removing the key and re starting, I can get it to engage.
I just had the 30,000km service and mentioned the problem but they said they could not fault it?? They said there was also no errors reported in the computer. I have booked it in again for them to look at in a couple of weeks but if anyone has seen this before, I may be able to give the dealer some direction.
If I get permanently stuck somewhere I will be might pissed!
Thanks
Rotelman
Passat MY09 125TDi DSG Wagon - Arctic Blue
Tint,Tow,E-Tailgate, Roofbars & Cow,Fog, 12GB SDHC
VW Bluetooth
