Results 1 to 10 of 60
Thread: VW decides to replace my DSG Mechatronics unit!
    Jul 2010
    I've just had my mech unit replace under stat warranty. I bought the car second hand (1 day out of factory warranty) and it was jerky takeoff, jerky reverse (with NO throttle!) and clunking when rolling away from stationary and no throttle. Happened the first night I got it, only when warmed up.
    Just wondering, once they've replaced it, does it mean it won't happen again? or is it a wear and tear (thermal stress etc)? I wouldn't want to pay for a mech unit 4 year down the track cos it would have been $4500!
    Nov 2010
    Burpengary, Queensland
    Quote Originally Posted by johnw View Post
    They told me that mine was faulty and the replacement was a rectification of the known problem, so I too am hoping that it will last.
    Jul 2010
    Robina Gold Coast
    Good on you , but i have the same trouble with mine except no one can decipher what the read out is saying, VWA has no idea and had to forward the bad code read out to VW in Germany
    even they cant work out what causing the trouble except to suggest up grade all the software , which did nothing so now i;m waiting again to hear back from Germany as to what the next step is, The dealer said his hands are tied and can only do warranty work with VWA approval.
    Barloworld has told me no one has ever seen what my car is showing on the VAG unit and doesn't know what to do , said i might have to leave my car with them for a week for further investigation and no loan car because its a warranty job .
    May 2010
    vic
    Any one living in Victoria?
    can we gather up and compare the jerkiness?
    I'm sick of imagining how jerky other people's DSG unit is.
    Jul 2010
    My car was 08 Passat from Barloworld Glenwaverley. I had to leave my car there for about 2 weeks for them to diagnose the problem. They said they sent the log files to VWde for analysis as they didn't know what it was.
    The jerkiness I felt was big, as in when I was following my wife when picking up the car, it was bunny rabbit off the lights, I could SEE the car jerking at takeoff. And the I could not park in the garage as I can't roll with no throttle, it'll just launch to about 10km/h from standstill.
    Basically it was like driving a car with a brass button clutch when trying to learn manual
    May 2009
    Well just to add to the list of Passats with gearbox problems - I'm waiting on replacement clutch packs to come from Germany. Two weeks ago the car started vibrating as it was accelerating through 2-3000 rpm in 2nd 4th and 6th. You would also hear a rattle under light load in those gears - as well as the rev's flaring by about 100-200 rpm - felt exactly like a clutch slipping in a manual car.
    Finally was able to take it into the dealer on Wednesday, they had to keep the car overnight as they were being instructed by VW Australia to perform different tests on it. Had a phone call at one stage on Tuesday asking whether I had modified the car at all as there was an error code thrown up that usually only happens on cars that have been chip tuned or the ECU modified. The car is completely stock - but it took a bit of convincing to make them believe that I had not modified the car. I found it unusual that they wouldn't be able to tell this anyway.
    After keeping the car overnight and running some more tests on Thursday VW Australia has decided to replace the clutches in the car - so I have it back in the meantime and the vibration is getting worse as each day goes by. Todays drive home was quite eventful - will probably need to drive it in 1st 3rd and 5th until these clutch packs come in from Germany to get replaced.
    Pete
    MY13 Octavia vRS TDI DSG
    Jul 2005
    Quote Originally Posted by mebius9 View Post
    Am in vic... whereabouts are you? I'm in werribee.
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    May 2010
    vic
    Quote Originally Posted by blutopless2 View Post
    I'm in Rowville But I can come to Laverton since a lot of my friends moved there
    I'll just crash at one of my friends after visit.
    Anymore takers?? need more sampling pool!!
    Sep 2008
    Could do.. name a time and place, and I'll see how I go..
    MY08 Passat 2.0 TDI Wagon
    Trialling golf ball aerodynamics theory - random pattern, administered about 1550 on Christmas Day, 2011.
    May 2010
    vic
    Quote Originally Posted by passatpout View Post
    Excellent!
    blutopless2 do you know any low traffic area around Laverton for the FGOTY contest?
    One more Passat owner would be great though.
    Anymore takers??
