From what I can gather, it's factory-fit only, and not available as a 'kit'.
In saying that, there looks to be part numbers for everything needed to retro-fit it, and there are a lot of parts to it.
Essentially, parts 60 through to 91 are required, and in multiple quantities in some cases.
One uncertainty, would be wether you can still use the existing inner quarter panel trims that accommodate for the front luggage tie-downs, as the brackets for the tracking setup, uses those mounting points.
