We have a Subaru & the Skoda. Swap reasonably well between the two. I find the "Euro" setup to be more natural & safer of the two eg: you keep the right hand on the wheel & the left is used for changing gears & indicating, flashing high beams etc. Occasionally I stuff it up whem I'm in the Subaru - don't people know that spraying the windscreen with water means you want to pass?
The Belgium built Mondeo we had before the Subaru was also Euro pattern as was our 98 Golf
I find I muck it up more in our two Japanese cars, than I do in my Polo.
Same goes for selecting reverse.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
On automatic transmissions, the selector pattern was part of an ADR, however I understand as it has now become industry standard the ADR has been withdrawn.
P R N D
After D, you can have additional forward gear options.
To go from Drive to Reverse, you must go through Neutral, and Park cannot be adjacent to Neutral or any forward gears.
Argh, that's because I was half-way out of the door when I wrote it. Re-reading it, I myself went WTF? Not even my very first car, a Citroen 2 CV was that screwed up. I now haven't the slightest idea what I was visualising when I typed that in! Good lord!
Of course, it's as you said and my curiosity was about whether it would be mirrored to reflect some concept based on driver proximity - so 2 o'clock, 4 o'clock, noon, 6, 10, 8 and R push-down and RIGHT & up.
PS: just remembered what the 2CV actually had and something in my hindbrain must have linked to that: 8 o'clock, noon, 6 o'clock, 2 o'clock - and reverse was hard far-shift to right then up. Really!
