Results 1 to 10 of 13
Thread: Vagcom / VCDS DRL coding
    May 2007
    Hi All,
    Just wanted to see if anyone has activated the DRL's on a VW Passat with OEM Bi-Xenon Headlights?
    Vagcom / VCDS Byte 0 in 09 - Central Electonics;
    - Byte 0 Bit 03 – Daytime Running Lights (Scandinavia) always active.
    - Byte 0 Bit 04 - Daytime Running Lights (North America) only when handbrake off or car in gear.
    All off the above work when the light switch is in the “0” position only.
    As stated above, i have tried the (Scandinavia) and have found that my Low Beam (Xenons) are always on.
    I have also tried the (North America) and have found that it works when the handbrake is released or the car is put in gear; which is exactley how I would like it to work, however it once again uses the Low Beam (Xenons) which I do not want to use!
    Does anyone know how to activate the North American Style DRL, only using the "parking lights" instead of the Low Beam Xenon's?
    Could it have anything to do with the Extra Function or Replacement Function as descibed in the following;
    http://en.openobd.org/vw/passat_3c.htm#09
    Jimmy has been helping me with this, however we have not explored futher than what is mentioned above.
    Open to suggestions or advice!
    Feb 2010
    NSW
    Sorry if this is a silly question but why would you want parking lights on while driving? If it's for safety surely Low Beam is what you'd want.
    May 2007
    Quote Originally Posted by J-P View Post
    J-P, thanks for your question.
    I do not want to run my Xenon Bulbs 24/7, as simple as that!
    As with the new MK6 that run DRL's, they use the parkers (forgive me if I am wrong). The headlight cluster in a Bi-Xenon Equipped Passat has a large plastic disc that projects the light of the parkers very nicely indeed! So long story short, during the day, the parkers almost look like low beams (if that makes sense).
    Feb 2010
    NSW
    I see. Is the low beam on at 100% or dimmed? I'm not an expert but I'd say Extra Function is for having a second light on at a certain percentage and does not replace the primary lights, and Replacement Function replaces the primary lights and looking at the list it doesn't bode well for what you are trying to achieve.
    Scandinavia might have dedicated DRLs since there's an Extra Option to also use Low Beam. I wonder if these can be fitted. Found this which might help and also mentions a Byte 20 function. You might be able to have parking lights as an extra and disable low beam for DRLs which will leave parking lights in use.
    Apr 2009
    Melbourne, VIC
    Plus, change the parkers over to some LED globes (with built in resistor) and they'd look even better as DRLs.
    Pretty sure you can manually set the lights to only have the parkers on can't you?
    May 2007
    Quote Originally Posted by Rocket36 View Post
    Yes, by turning the switch to "parkers" the parkers only come on. (parkers / rear lights / instrument cluster)
    However, if they were set up via VCDS as DRL's only the front parkers would come on, not the rear lights or the instrument cluster. That is how the OEM DRL's work.
    Apr 2009
    Melbourne, VIC
    Ahhh gotcha! That makes more sense... That would be a good mod to do IMO. Especially with the LED parkers.
    Jan 2007
    brisbane QLD
    From memory you can select front fogs or low beams, but not parkers...
    Main Dub:
    2010 Crafter Hanover Bus
    1956 Type 1
    2015 vRS wagon black on black
    Feb 2008
    Perth WA
    Has anyone with a Passat with xenons worked out how to activate the drl's?
    Mk 7.5 Golf R
    May 2007
    Quote Originally Posted by guthrie View Post
    Guthrie, best bet would be to get VW to do this for you. I see heaps of the new model Passats with Fogs as DRL's.
