I recently purchase a pre-owned MY09 Passat with RNS510, Dynaudio. I want to understand what version of Map and Firmware I have on the system as I am keen to upgrade to get:
- digital speed display on MFD
- Speed limit display on map
- shows clock when switched off
- dual zone controller Climatronic control
- Faster Startup
- SDHC 32 GB Support
From the threads I see that I need to get a VAG Com to enable the 'secret menu'. I have asked the local VW dealer in Chatswood however they are not interested. Can anyone help or suggest a shop that will do this for me ?
Hi Spanky,
I would like to be able to assist but I'm a little far away from you but I'm sure there are plenty of guys near you that can assist. Failing that go to Firmware Updates | my-gti.com and you may well find the answers you need there. If you get desparate you could always buy a VCDS (VagCom) setup and DIY!
Cheers and good luck
Murray
