thank Guys,
No orange lanes in the centre of the dial, thats what made me curious, as side assist green exterior was on, camera is there, and buzuki, it has a towbar fitted with the modified light cable I have noticed for the issue with the LED tail lights. I have it booked in at the dealer local dealer for Valentines Day.
Hi Harry
Dont panic on this one. My B7 FSI was delivered last February and I had the same issue. If you can see the camera above the rear view mirror as some of the guys have posted on your thread, then it is there. It just requires your dealer to go into the VCDS and select the option. I found VW is very inconsistent with this and a few other issues with programming.
Enjoy the Passat... the V6 is beautiful and the exhaust note gets better as you get a few KM on it.
Shepp
Thats a Blackvue DR400G but I have since put a DR 500G WiFI into it
camera is there, BTW like the desert Beige interior would have prefered it to black as it does not show sand as badly. HOpe fully should be fixed come thursday. BTW does the passat have the static cornering lights enabled? just wandering as I can only seem to get one set of fog lights to work with the switch.
2013 V6 Passat Candy white, sports pack, towbar, Drivers visability and assist.
Problem fixed by my local VAG, apparently did not have the correct region coding, an issue which appears with the towbar installation. Now the static cornering lights and lane assist are both working.
CHeers
sweet, i was right with the towbar then.
