16GB Kingston SDHC card = not working.
I have a MY09 too (same MFD) but my stereo unit is different to that one. I tried to get a HCDS car to work but couldn't.
Yeah I can't get any of the HDSC cards I have to work... No matter as 4 DVDs and the HDD was full!
I have a TRANSCEND 16GB SECURE DIGITAL HIGH CAPACITY CLASS 6 CARD as found on link below and it works just great.
http://www.hboutlet.com.au/catalog/p...ucts_id=199204
Make sure you first FORMAT the SDHC card as FAT32 and then it's a matter of just copying your MP3 files onto the SDHC card..
Do you get the "Processing" message on the RCD510 when you insert the SDHC card?
I have just ordered 2 x Transcend 4GB SD cards from techbuy.com.au. Apparently they are the biggest non-SDHC SD cards you can get, and they are getting to be hard to get.
Reading through the Jetta / MK V forum - looks like the RNS 510 has been around for a while (?since the 1st gen MkV golf), whereas the RCD510 is a recent development for various MY09 models & golf Mk6. Perhaps this explains why one is only SD compatible while the other has the up-to-date SDHC format.
In terms of why VW hasn't upgraded the existing RNS 510 in line with the new RCD.... the more I read into the forum, the more it seems that VW habitually and sporadically "updates" features on their vehicles, even between significant MY intervals.... creating a lot of confusion about "who's got what function" in the process!
I am sure with a firmware update the rns-510 to could sdhc cards no problem. i am sure i have read of people using them in fact in iverseas forums.
Swallowtail, I might be wrong, but I'm almost certain that SDHC is 4GB and up and non-SDHC is 2GB and below. So not sure if they will work in your RNS.
