Results 1 to 7 of 7
Thread: Unleaded in a Diesel
    Jun 2008
    Newcastle NSW
    The missus just gave me a call to say she accidentally filled the tank with 600mL of unleaded before filling the rest of the tank with diesel.
    Should be a problem if it's that diluted right?
    Erskineville, NSW
    600ml wouldn't concern me if it's diluted in 50L of diesel.
    Jan 2011
    ACT
    I would be concerned. If you're absolutely positive its only 600ml in 50+ litres then its definitely at the lower end of the risk scale. Monitor closely, as by now I'm assuming you've already driven it?
    Nov 2010
    Just continuously keep topping up the tank for this week, you will dilute it to nothing in no time.
    May 2010
    vic
    It should be fine I think
    older diesels could actually run on unleaded for short period
    But I'd imagine pure unleaded fuel would detonate in the piezo electric chamber costing millions of dollars to replace.
    Actually... I just figured Hydrocarbon don't burn without oxygen so your piezo injector should be fine...
    Jun 2008
    Newcastle NSW
    Thanks everyone. She drove it home with no ill affects.
    Called the guys at VAG Australia who confirmed won't be an issue.
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by mebius9 View Post
    Much more likely to melt the exhaust impeller in your turbo due to soaring EGTs, but at such a low dilution I agree there would be no ill affect.
