Results 11 to 20 of 21
Thread: Tyre replacement
    Nov 2012
    Perth, WA
    Michelin Pilot Sport 3 - great tyre, so good for around $220 a corner. Only time its stepped out is at 60kmh in the wet around a corner.
    R36
    Aus
    Michelin PS3!
    Current: | MY09 R36 | Dynaudio | RNS510 SatNav |
    Jan 2013
    What about ps3 wear?
    Sent from my GT-I9305 using Tapatalk
    2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
    Feb 2014
    Michelin PS3s are my preference for noise and handling.
    I have Michelin Pilot Sports 3 on the 125TDI and Continental Max Contact MC5 on the R36 - much prefer the Michelins and will be putting these on the R36 as soon as the Continentals wear out.
    Originally had Pirelli PZero Neros on the 125TDI and they made a terrible noise (thudding sound at low speed - like a flat spot). I actually thought there was something mechanically wrong with the car and had it checked out a couple of times...
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by saint70 View Post
    The PS3 is well known for an excellent combination of dry and wet performance with good wear
    I have a pair of PS3's on the front of my Skoda Octavia (APR Stage 2 ~200kw)
    They have 5.5mm of tread after 22,000km
    They are likely to last ~52,000km down to 2mm of tread
    Jan 2013
    Is ps3 noisier than potenza adrenaline r002?
    Feb 2014
    Don't know how Potenza Adrenaline r002 compare, but I've found PS3 to be very quiet.
    Jan 2013
    Thank you for your answers. Very helpful..
    Feb 2008
    I had Conti SC 5P on mine and loved them. They are soft though and you will definitely wear them out before they go off.
    Needed to replace two and was unable to source them in Melbourne, so instead got 4 Hankook Ventus S1 Evo 2 and they're great as well. Dry performance is as good. Not quite as good as the 5P in the wet, but still pretty good.
    CR Audi RS3
    PW Golf 7 GTI
    Jul 2013
    Hills District
    +1 for PS3, I will give PS3 a go after I finish with the OE CSC3 ContiSeal
