Originally Posted by
Radius
Hi team again,
Sorry for the separate post but a separate question - What tyre pressures do people prefer to use on their R36's, and do you vary them according to your usage?
I run mine at around 2.5 bar (250kPa) for normal use, which is similar usage as yours. I haven't had any issues so far. If I know I will be doing some high speed cornering, or have a long trip with a full car then I might increase the pressures. Tyre pressures are a bit of a trade-off, higher pressures = better cornering, better fuel economy and quicker wear, whilst lower pressures = more 'rolling' of the tyres through corners, higher fuel consumption, more comfort and a more even wear across the thread. I usually check how the tyre is wearing, if it is wearing more in the centre, then I deflate slightly. I would not recommend going below 250kPa though as too soft means more heat generation and quicker wear, as well as too much sidewall flexing. The placard is a general guide and caters for a broad range of use, for obvious reasons. Best is for you to try a few different and work out what works for you.
Good place to start is this forum and check what others are going (as you did).
Good luck!
R36 Wagon, blue, sunroof, towbar, auto tailgate, MDI, and now with upgraded sound system
1969 TL1600 Fastback
Suzuki GSX1400, Yamaha XVS1100 Bobber
....fairings are for scooters!
