Results 11 to 20 of 36
Thread: Tyre pressure sensors
    Pacific Paradise QLD
    Quote Originally Posted by Timlin View Post
    Hi
    There's a repair kit?
    I didn't know that, thanks for the tip!
    I'll do a Google search, but do you know where to get these kits?
    AT
    " you should consider buying a repair kit from VW (part no. 1K0998275A) for around $48 per sensor"
    Apr 2013
    Hillbilly
    Mate, you're a legend! Thanks so much for the detailed response. I'll call them now!
    AT
    Hillbilly
    AT
    Was in reply 7 actually I just copied it
    Apr 2013
    Hillbilly
    Why, yes it was! I didn't notice it as I sped read it...
    Thanks again!
    AT
    Apr 2013
    Hi Diesel Vert
    Thanks for the highly detailed answer! I've now ordered 4 x seal kits (from ECS) and that may be the end of this particular problem... no doubt, there will be a new problem shortly after this one is solved!
    But wait, of course there's still the auto closing tailgate that doesn't auto close, even after VW Artarmon fitted a new motor in the system, then there's the cargo bay room light that used to work after said VW dealer "fixed" it, but it doesn't want to play anymore... and when these things are fixed, there'll be something else, it's the original never-ending story!
    Thanks again for your input!
    AT
    Hi Diesel Vert
    AT
    Does the tailgate open but not shut Maybe its the switch not the motor Same with the light
    Apr 2013
    Hillbilly
    Yes, it does open, and it did close itself for a few weeks after VW replaced one of the motors under warranty, but then it just stopped performing one day. I did nothing wrong, it wasn't forced or anything like that, it just stopped working. Now I have to force it to close by hand and it just doesn't feel right as the resistance is very apparent.
    My VW mechanic suggested that it could be a sensor fail somewhere... I dunno, it's very annoying though. The last time VW "fixed" it they had the car for a week!
    It could be the switch I guess, it could be anything, I just don't know. It goes back to VW on the 11th of June, so we will see what is revealed then I guess.
    AT
    Apr 2013
    Hillbilly
    AT
    Hillbilly
    AT
    It does take quite a push to close it by hand as you are also working the motor.
    It says that in the manual
    Apr 2013
    Hi all
    A TPMS update. I ordered the seal kits for the sensors, had them fitted and the wheels rebalanced and all was good... then today, the damn light comes on again. Low tyre pressure it says. So I check the tyre pressures on all 4 wheels and adjusted them all to show 40psi each. The light goes out... for a while.
    Then this afternoon it comes on again! So, I checked all the tyres again, all still at 40psi, so clearly theres a fault. I try to turn the system off to reset by holding the button in for about 30secs. It turns off, and then a few minutes later it turns itself on again - without permission!
    And the usual warning light comes on again, so I keep turning it off - it turns itself on... I'm getting bored with this now. I've never had a TPMS on any of my previous cars and I think I can probably live without it - I mean, it doesn't work anyway... So I'm thinking just remove the fuse and be done with it.
    But, which fuse is it? Theres no ID on any of the fuses under the bonnet, so I'm stumped now!
    Any ideas/suggestions??
    Thanks for reading too!
    Rgd's
    Andrew
