If it's using rotations to determine tyre pressure, how is it monitoring the pressure in the spare wheel?
It is probably not monitoring the spare. The only way to do that would be to have a transmitter in the spare and a receiver in the car. IIRC that was how the original TPMS on the early GTIs worked, then some bright engineer realized they could use the ABS sensors to measure wheel rotations, thus saving costs.
So it is up to owners to check the tyre pressure of the spare manually (and going by some of the posts on this forum I'll bet an awful lot of people can't be bothered to do so).
I'm no expert on TPMS but thinking about this logically, it would be impossible to use a single tyre rotation as the basis for determining rotational speed. Every time you turn a corner (or go around a bend) there is a difference in the rotational speed of the wheels on the inside of the corner Vs the wheels on the outside of the corner (thus the need for a differential on the drive wheels). There are numerous circumstances where rotational speeds would vary momentarily so if TPMS acted instantaneously it would give repeated false alarms. Therefore, I would think it can only operate by monitoring over a period of time.
George
06 Jetta 2.0TFSI Killed by a Lexus!
09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
14 EOS 2.0 TSI has arrived!
I was told by the sales person that it monitors the spare wheel as well.
A friend's Dodge Caliber monitors all five wheels so I didn't think it was science fiction!!!!
Perhaps the salesman was mistaken (or dare I say, lying) that has been known to happen.
This may be true but in order to do so would require a pressure sensor in each wheel transmitting to a monitoring system or alternatively some sort of voodoo magic system. In my VW there are no sensors in each wheel, are there in yours?
George
Yup, the Phaeton made a big deal of this.
I am pretty sure they abandoned the idea as it used to trip out all the time.
As the MFD used to be able to say "low pressure - right front" it made a huge mess when tyres were rotated etc. as the system needed to relearn where the tyres were on the car. It also meant if you changed a flat tyre the MFD would continue to show a fault after you repaired it.
I think the R36 System relies on ABS sensors, to monitor wheel rotations. It does this over a long period of time, not just one rotation, as someone said there is flex in a tyre and it would go off every time you went around a corner or hit a bump.
It is not a failsafe system. Nothing replaces the need to regularly check tyre pressures and fluid levels in your car.
Confirmed Global Warming Sceptic. No Longer a VW Owner -Loving my new 2011 Range Rover Sport - bought as VW unable to provide info on the new Toureg despite it being released overseas 12 mths ago. 2008 R36 Wagon, 2006 GTI and 2004 R32 - Gone. Sorry VW, you make great cars but until you improve your customers' experiences you will lose customers
