With the stock comp of the 3.6L motor you wouldn't be able to run anything over about 6-7psi without a rebuild to lower the comp ratio.....I had a very good look under the bonnet at the motor show with this idea in mind and there is alot of room around the headder area for a turbo setup....have you got anymore info on the HGP kit?
