I'll move this thread to the Passat forum - this is for car audio etc.
As to the issues - yes you may have problems. LED trailer lights can cause issues - I have standard bulbs in mine so can't help you with that one though.
The rear parking sensors - if they activate when the trailer is connected then the car needs to have some coding changes so that the electronics know when you have a trailer on board. If it is done properly then you will not have any issues - on mine, when a trailer is connected the rear sensors disable, and the Optical Parking System comes up with a picture of a trailer. See your dealer to sort that out if it is not the case.
Your tow kit should have come with an adapter cable about 300mm long that goes from the 13pin round to the Aus 7 pin flat. Again, if you don't have that then your dealer should be able to supply. The adapter cable has some diodes in it, it is not just a straight wire swap.
