Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 112
Thread: Towbar Information
  1. #71
    Hey all
    I have a quick question that I have soured the net for but have come up empty.
    I have a 2014 passat alltrack wagon with the electric boot option and when a trailer is connected the boot will not completely open, this is annoying when my trailers are attached but I would like to be able to activate this feature with my bike rack is attached to the tow ball. I am always stresssed that i will accidently open the book onto the steal bar of the rack and destroy the boot lid.
    So any ideas which wires on the trailer hitch need to be activated either with a light or being bridged to deactivate the boot opening.
    Thanks in advance
    Ben
  2. #72
    Dec 2008
    Sydney/Canberra
    Do you have the 13-pin/7-pin adaptor fitted to the car permanently?
    If not, plug that in, and that should sort it. There's a micro-switch in the cover on the female 13-pin round plug on the car.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  3. #73
    Quote Originally Posted by Umai Naa!! View Post
    Hello
    Yes I do have that adaptor cable connected at all times. in what state does the micro switch operate? as my electric door does operate normally when no trailer is connected and only pops open when a trailer is connected.
    I have done an extensive look through the vcds but even there i cant get into the electric boot adaptation page as the nominal security code that works on every other car doesnt work for mine.
  4. #74
    Jul 2010
    Elanora Heights, Sydney
    Is it a genuine ECU for the trailer plug?
  5. #75
    Yes everything was factory fit
  6. #76
    Jun 2012
    Maroochydore, QLD
    Tow Bar for your Volkswagen - genuine VW option inc. module Germany - Westfalia
    Euro Car Upgrades has become a dealer for Westfalia tow bars in QLD
    This is the system you get when you order a car with a towbar from VW Frankfurt or VW Berlin
    Invisible and some say it has a bit of a sexual appeal when dismantled... keep it away from the missus
    What do you think? Its cheap as well - check out some options here
  7. #77
    Apr 2009
    Northern Tasmania
    I have one of these on my Skoda Octavia and it's excellent. When the gooseneck is off you can see no sign - nothing to rub on driveways. There is a little cap that goes on the key slot to keep dirt out. Has a 13 pin socket.
    My only criticism is the loop for the safety chain is high up and hard to connect a shackle to, but if you leave the shackle on it rattles or you can see it when the gooseneck is off. Maybe a rubber sleeve around the shackle would work to stop the rattle.
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
  8. #78
    Mar 2015
    Balwyn North
    ECU?
    Guys
    I have a 2014 AllTrack and have read all the posts.
    I need a tow bar but am extremely concerend about some of the awful jobs I have seen on this forum and in the flesh.
    I do not trust anyone enough to cut out the shroud and would be quite dissappointed in a non symmetrical solution therefore would prefer the Westfalia option.
    I contacted Westfalia and their nominated dealers and was not really impressed with their responses with regards to my questions concerning the rear sensors and reversing camera operations. One guys said yeah you'll get used to it and the other didn't seem to understand that we need to bypass/disconnect these functions when we hooked up a trailer.
    Further research has led me to a DIY option which seems resonable in price hoever I an concerned with their technical solution. Can anyone shed any light on the follwoing which is from the vendors web site:
    Vehicles since the 1980`s have been fitted with Can-bus or Multiplexing wiring, a system designed to cut down on the amount of wiring required in a motor vehicle, to save weight, improve fuel economy as-well as to capitalise on new technologies making vehicles more user friendly with improved creature comforts and of course safety. This vehicle wiring system uses a series of electronic control units (ECU`s) to control various aspects within the vehicle.
    When another electronic component is required to be added to this arrangement it can cause issues if not installed correctly. The vehicle’s ECU`s can basically get confused and send out warnings to the vehicle that there is confusion. Therefore, when adding a trailer connection harness to a vehicle an additional electrical component or ECU may be required. This can be done in one of two ways.
    No. 1 Directly incorporated into the Can-bus system.
    An additional ECU can be incorporated directly into the Can-bus system so it will communicate with the other ECU`s hence turning off reverse sensors / camera`s and modifying ABS, traction control and stability systems. This installation is normally carried out by the vehicle manufacturer at the time of genuine towbar fitment. It is time consuming and can be expensive as existing on-board ECU’s may need reprogramming to accommodate the towbar installation.
    No. 2 Connection via a Bypass / Intelligent ECU.
    A Bypass ECU (Intelligent ECU) is simply attached to the vehicle’s rear light wiring harness and takes a signal from the harness telling the Bypass ECU when the vehicle is indicating, braking or the lights are turned on. This type of ECU draws little current and therefore causes no issues for the Can-bus system.
    Certain ECUs can detect the different voltages sent on a shared wire circuit (sometimes vehicle manufacturers will use a brake and tail light signal through one single wire especially with LED lights) and therefore can determine how the output signal is sent to the trailer.
    As the Bypass ECU has its own separate power source it can safely send the correct signals to the trailer connection plug wiring without any issues or effect to the vehicle’s other sensitive circuits.
    So the my question is Option 1 or Option 2?
    Thanks Kenneth
  9. #79
    Apr 2009
    Northern Tasmania
    Option 1 is the correct way. That's how the factory do it. It's how the better aftermarket makers do it. Rear parking sensors turn off when you attach a trailer. The car goes into 'towing' mode ABS/ESC wise. It uses the gooseneck removable Euro style bar. No sign of it when off. More expensive attachments than for the square hitch style or older flat style bar. It is also expensive to install, and hard to find anyone that knows how to do it (even dealers).
    Option 2 is the quick and dirty way to do it. Most likely the car won't know you are towing so it won't do the ABS/ESC adjustments. May not matter if you only tow a small trailer, but for bigger trailers, boats and caravans - it might not be a good idea to go cheap on this.
    If you're at all fussy go for option 1. You can do it yourself, but it requires research, a good kit and programming of the car after by VCDS or dealer to let the car know it has trailer wiring in it.
    I used a westfalia bar (imported from the UK) on my Skoda Octavia 4x4 and a kit from PFJones.co.uk. Bar install is one of the best I've seen on here and the electrics work properly, though I'm not convinced the car knows it has trailer wiring (despite PF Jones assuring me it should once programmed). The reverse sensors work properly and I get a pic of car with trailer on the satnav screen when reversing so all seems ok. Current kits there mention trailer stability.
    One difficulty is what socket you put on the back of the car. Tricky if you want fridge power to a caravan. The 13 pin doesn't seem wired up for it. Can't remember the details - it was a while since I did it, but I did a good write up on here about it.
    https://www.pfjones.co.uk/tow-bars/t...k-towbars.html
    https://www.pfjones.co.uk/towbar-wir...ring-kits.html
  10. #80
    Oct 2013
    VGA803921PAS06 T/BAR PASSAT B6 06> ALL, $486.31 retail. In stock.
    3C9055204G supersedes to 3C8055210 R36 WAG T-BAR WIRING, $541.46 retail, in stock.
    does anyone know if these are still valid? looking for a tow kit for the R36
