I'm trying to wire a 13-pin Euro plug to 12-pin flat socket adaptor. Posted this in the Skoda Octavia section but thought Passat owners might know the answers. My thinking is it'll end up the same thing as the VW 13-pin to 7-pin adaptor, but with the added function for caravans/heavy trailers (because 7-pin can connect to a 12-pin also).
Issues are:
a. 13-pin Euro has no electric brakes pin. How do they do electric brakes in Europe?
Could you connect pin 5 on the 12-pin flat to the stop lights pin (pin 6 on the 13-pin) just for the signal, but get power for the electric brakes from pin 9 (ignition switched power 12-pin), then put a relay in the caravan? That might work for your own caravan (where you can custom wire it), but you really want to do it in a way that works for all. How about a relay INSIDE the adaptor lead?
I'm a little unsure how powered trailer/caravan brakes work. From my reading the above solution may not work as the power for electric brakes needs to be variable because caravan's brake force can be varied by the driver.
Maybe for a custom wired adaptor (only for your caravan) you could use pin 12 of the 13-pin Euro for electric brakes (since it's currently not used)? You'd have to add that function to the socket on the car.
Or use the first solution but with caravan brakes that can be adjusted on the caravan (so obviously couldn't be varied when driving)?
b. 13-pin Euro has a right tail and a left tail pin. 12-pin flat has the one tail light pin. How's this handled in the VW adaptor?
Originally Posted by scoutau
b: The car needs to be told it is located in Australia, this changes the wire detection to allow for Australian single bus (One wire for all park (wfdTamar - do you mean tail?) and one wire for all Stop lights.) 7 conductor trailer wiring instead of the dual bus (Left and right side of trailer for stop and park (tail)) used in Europe.
Originally Posted by IanHamilton
b: This also has been cabled for in the 13-7 adapter. Pins 5,7 of the 13 go through diodes to pin 7 on the 7 pin.
Swallowtail:
5 and 7 from the 13 pin are each fed into a IN5404 rectifier (rectifier or diode?), and then joined together and connected to the 7 pin conenctor number 7 - which is for tail lights. The rectifiers have a reverse impedance of 1.7kohms.
But didn't someone else say only pin 5 (of the 13-pin) is connected to pin 7 and the Australian coding takes care of that? Any more detail about those diodes? What value are they and how are they wired up? Any chance of a good photo? Do both pins (on 13-pin) get connected to pin 7 (12-pin) or just pin 5 (13-pin)?
c. What do you connect the earth return on the 12-pin flat (pin 10) to? Euro pin 10, or pin 13, or both? If both, does that require a diode(s) too?
I'm not terribly familiar with diodes and stuff in that area (could ya guess?).
13-pin round Euro
1. left indicator
2. rear fog
3. earth return
4. right indicator
5. right tail & sidelights
6. stop lights
7. left tail & sidelights & number plate
8. reverse
9. permanent 12 volt (interior lights and charging)
10. auxiliary, ignition switched 12 volt (fridges)
11. earth for pin 10
12. signal connector (not used on VAG cars)
13. earth for pin 9
12-pin flat (and the Euro pin it's connected to)
1. left indicator (1)
2. reverse (8 )
3. earth return (3)
4. right indicator (4)
5. electric brakes What do you connect this to?
6. stop lights (6)
7. tail lights do you connect this to the Euro 5 & 7 - how?
---------(pins 1-7 are the same as a flat 7-pin connector)---------
8. permanent 12 volt (interior lights and charging) (9)
9. auxiliary, ignition switched 12 volt (fridges) (10)
10. earth return (11 or 13 or both?)
11. rear fog (2)
12. aux/spare (seems not used)
