Be careful using LED lights. They sound great in theory but I recently had issues with my trailer lights working intermitantly on the VW after the towbar and electrical harness were replaced by the panel shop after a rear ender. The trailer lights worked fine on my other car.
The Dealer tested the VW electrical harness working fine using a test board made up with standard (non LED) trailer lights. When discussing what could be wrong elsewhere in the trailer wiring that could cause them to work on one car but not the other, the first thing he asked was if the trailer had LED lights.
He advised that the VW harness is set up to work with standard incandescent trailer lights and is very touchy with LED lights as they need to be wired with resistors to restore resistance to match non LED lights. It can take a lot of trial and error to get the setup to work with LEDs.
As it turned out my problem was fixed by replacing the 5 core wire from plug to the rear terminal block that then feeds to the lights, even though the old wire was OK. A subtle variation in wire resistance between the new and old wire was enough to affect the lights working when connected to the VW.
Granite Passat sedan TDI (125kw), DSG, beige leather
Candy White Polo 6R, 66TDI, DSG, no options
