Towbar
Originally Posted by
Passat
IRemember: For $1400 you get also a protector cap for your towball AND a bag to store the towing tongue when not in use!!
I have ordered a VW accessory towbar to be fitted when the car is delivered for $1430. I was advised that it has a fixed tongue (standard 2 bolts) as is common for many lighter weight towbars. The aftermarket quote I got also stated that their (TJM) towbar also has a fixed tongue.
It sounds like you got one with a removable hitch as is commonly used for the higher rated towbars on SUV's etc.
Is this correct, and if so what is the rear ground clearance like?
Granite Passat sedan TDI (125kw), DSG, beige leather
Candy White Polo 6R, 66TDI, DSG, no options
