Results 1 to 10 of 11
Thread: ticking sounds from engine
    Aug 2006
    hey guys, when my car idles, it makes ticking sounds non stop. its pretty loud also.
    what could it be?
    i wouldnt have the money to fix it for awhile, does it sound ok to drive for a month or 2?
    syncro Guest
    Lifters
    If it is;
    What oil do you use?
    What filter do you use?
    Do you do short trips?
    Does it go away after driving for a while?
    Feb 2007
    sydney
    when did you tune - up your engine ?n:
    It could be a valve ticking..easy to be fix and no cost to much..
    Is it a diesel engine ?
    Aug 2006
    lol nnot diesel, and no tune.
    i'v noticed that it ticks when the engine is warm.
    also its time for engine oil change, every 7500. which oil should i be using? it has 127000 and i think the last time i used 10w50 or something similar.
    so how do u fix the valves ticking?
    Sep 2006
    Australia?
    Quote Originally Posted by 1DUB2C
    Recondition the engine. Sounds like a pretty big job ray. I used to here that on the old vr6 ticking sound all the time. Check the timing belt pulleys they could be lose.
    Jul 2005
    Melbourne, Williamstown
    it'll deffinately be the tappets sticking, which can be either replaced or, recoed by you...
    ref..
    http://www.vwwatercooled.org.au/newf...ead.php?t=2183
    mk2 GTi 16v
    Corrado G60
    Jul 2005
    I did an oil flush on my car which cleaned up the ticking noise a lot.
    mk2 GTi 16v
    Corrado G60
    The problem most likely is your oil pick up is full of slug which staves the top of the motor of oil this is because thats the last place the oil reachs. If i was you i would pull the sump off clean the pickup and the go from there its a cheap exercise to do. just my 2 bobs worth
    syncro Guest
    Quote Originally Posted by passatwagon18t
    I would go with this, then put a genuine filter on and some Mobil 1 oil.
    Aug 2006
    thanks guys, i'l give it a try.
Similar Threads
  1. VW bora V6 4motion - engine problem
    By sim2002 in forum Mk4 Golf & Bora and New Beetle
    Last Post: 14-11-2011, 08:00 PM
  2. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  3. 2.0 Tdi Oil
    By TDI DSG in forum Fuels and Lubricants
    Last Post: 02-01-2008, 08:37 AM
  4. Replies: 16
    Last Post: 03-07-2007, 10:31 AM
  5. Gen 3 TDI engine conversion
    By dieseldude in forum Diesels
    Last Post: 13-04-2007, 04:17 PM
