Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: TDI regret
    Dec 2008
    Sydney/Canberra
    Whoah...
    Honestly, the biggest problem with DPFs is people NOT driving the car for long enough. Short trips, and infrequent use. The DPF will regenerate in the right conditions on it's own. Failing that, you could always ask to have the soot build-up checked, and the DPF regenerated at every service. Afterall, it's just a filter, and filters need to be maintained.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2008
    Sunshine Coast
    You are in a great position.
    As Aydan has already said, the common rail engine is EXCELLENT for a DPF, as it can control fuel injection and atomisation far better than PD can, and less soot is a result, all day, every day. The MK6 DPF design is entirely different to the problematic MKV, the first generation of DPF. In the MKV, the expensive platinium catalyst is combined with the physical Silicon Carbide DPF filter component, so when the filter eventually clogs, you are stuck buying the precious metal component as well. In the MK6 they are separate, so the replacement cost for a MK6 DPF filter will be coinsiderably less. Given you can get remanufactured MKV DPF's at under a grand in Europe, the MK6 will end up cheaper again aftermarket, plus I am working on being able to provide DPF cores in the future, both stock and hopefully higher flow, it's an aim for my business.
    The DPF filter does not fill up over time per say, and even if it does, my car is still running the stock DPF and ECU, and at 85kms, is running better than ever. When I force a regen through Vag Com, I can still get my own DPF down to 1-2% clogged, and that's a long way from the 60% that causes error lights, and 80% that makes you visit a dealer. Miro is spot on mentioning Moreys Smoke Killer as much as he does, and it has dropped my DPF loading quite measurably, so I'd recommend you visiting Supercheap and buying a bottle, goes a long way for $30 odd.
    Finally as many have already pointed out, getting the DPF hot is a key thing, so many short trips tend to make it load faster, whereas a trip on the highway helps it passively regenerate, and burn those visible soot particles down to the nano's, out of sight, out of mind. Overall Diesel uses less fuel per km, so despite your correct assumptions about the possible effects of nanoparticles, you would be producing more pollution in total in a V6.
    The colder you can keep the air coming into the engine, the more O2 is available to burn, and the less soot produced. Reducing the EGR aids this process, and whilst EGR reduces NOX formation by keeping combustion temps down, even VW themselves say this produces more soot. Get some Morleys, do some spirited driving when you can, and look into hobbling the EGR somewhat.
    Jul 2011
    Quote Originally Posted by Greg Roles View Post
    Thank's so much for that info Greg. It's great to get the full story. There's so much info out there it's hard to sort through. You have reassured me no end. I will invest in the additive too, that's cheap if it does what you say it does.
    Thanks to everyone else for their reassurances too. I'm loving the car more everyday, and the diesel characteristics have really got hold of me. Hoping this one will be a keeper.
    Jul 2011
    Forgetting warrantee issues, would a CAI and better intercooler be worthwhile? Would a custom code be worthwhile? Lots to think about, although I promised I would keep this one stock!
    Aol live support chat. Michelle trachtenberg dating.
    Adult dating service uk, dating piney point. Online dating athletes.
    New adult dating free site. Dating mangum, dating ford.
    Chinese women and dating rules, dating brooklet. Dating violence college students.
    Conflicts of interracial dating. Sex dating in bathgate west lothian, dating wolfeboro falls.
    Dating michigan city, chat christian dating free. Dating nebraska.
    Dating myers flat, dating fort riley, dating grimsley.
    Jan 2008
    Sunshine Coast
    Intercooler unecessary, the stock one does a stellar job for a normal road car, I've tested mine extensively. The single biggest source of heat in the inlet ( after the turbo compression ) is the EGR, so getting an EGR blanking plate and drilling a 10mm hole in it to stop the error light from showing up, cuts down the problem dramatically, and for about $5 plus post from ebay UK. Single best idea for a TDI in my opinion for dropping soot, reducing crud buildup and assisting power production. Oh and get a catchcan - Provent is the go.
    Then tune it up, the torque increase alone from a decent "chip" in a diesel is amazing!
    Jul 2011
    Thanks Greg, I think I need to talk to you more - Wait, no I don't! so if I do contact you in a moment of weakness, please ignore me.
