Results 1 to 10 of 10
Thread: stupid question regarding tdi injectors
    Jan 2013
    hi,
    what would be first sign of injectors problems?
    Which series of tdi more likely has that problem?
    regrads
    Pacific Paradise QLD
    Quote Originally Posted by saint70 View Post
    hi,
    regrads
    The more information you provide the better the answer
    Like car model you are talking about
    Symptoms etc.
    Jan 2013
    Symptoms etc.
    passat 2009 TDi 125 W sedan with dsg...102.000km odometar
    Not specific issue but i am worrying about something which happened 2-3 times in 7 months..Still waiting 105.000km service..
    Just, i had power loss ...let say 2.00 rpm on 40 km/h... Because of thiws, I wsas thinking if I had problem with injectors because this is very common issue with tdi engines...isn't?
    Mar 2008
    North Lake WA
    Saint70, I just had a 105K service and there is an injector recall going at the moment to either replace them (if within a certain serial number range) and/or injector o-rings. So go get that service and ask about the recall. I have an excellent VW service centre looking after my Passat, and they are very honest with time to explain everything. My Passat didn't need any injector work given they were replaced at 60K in 2010.
    When my injectors died the car lost all power with the coil warning lamp illuminated. It restarted, drove home, then died again that evening for good. The only other time the coil light showed was when my battery was on the way out on a country trip late last year, causing the car to hiccup with coil warning light a few times. Starting was also a little poor, but the battery replacement fixed it.
    Report at 105K was a clean bill of health, should really be keeping the car but the lure of the Alltrack is too strong (bought on the weekend).
    WestOiler125
    MY13 Passat Alltrack
    125kW 2.0L TDi DSG
    Oct 2010
    Melbourne, VIC
    To the OP, check the 125kW PD injector failure threads in the Diesels section (a much better place to have posted this question since the issue isn't Passat specific). If yours engine is one of these, then it would probably just stop with no warning as WestOiler125 experienced. Sometimes, the car will restart once, other times it stays dead.
    Resident grumpy old fart
    Jan 2013
    Quote Originally Posted by WestOiler125 View Post
    Thank you for your answer...I have 2009 passat...hope still cover by recall.. Still have around 3.500 Km to next service...what do you suggest..Should I go straight to my service?
    I am using Burwin Vw service and they are excellent. Last time they fixed issue regarding rattling (recall issue too).
    Jan 2013
    I will check..thank you
    Aug 2012
    Perth WA
    Hi WestOiler125
    Would you like to share the name of your repairer. My 125TDI is due for it's 15,000km service in a few months and would like to make sure it is given all the TLC it needs.
    PM me if you like.
    Thanks
    Jan 2013
    I just booked with vw Burwin service...Let them to do things..
    Also, i was told...could be issue with sensor?!? so, we will see..
    Jan 2013
    Quote Originally Posted by kaanage View Post
    How I going to fin d out which engine i have?
    I know that is 125 kw tdi and nothing else
