Results 1 to 6 of 6
Thread: Steering column lock defective!
    Sep 2010
    Pascoe Vale, Victoria
    Question Steering column lock defective!
    Hi Guys,
    Getting this error more & more often now when trying to start my 2010 Passat TDI. Since I only just replaced the battery with a heavy duty VARTA (Silver Dynamic 780CCA 78Ahr) in April, I notice the issue only occurs when its cold.
    So before I book it in with the dealer just wondering if anyone else has seen this issue and could it be low voltage whilst cranking (I'll take battery back to the shop to get tested if that's the case) causing the fault which disappears once the key fob is removed & engine restarted.
    I've even tried lately pushing the key fob in until all the lights go out before actually cranking the engine & turned off the headlights but like I said I'm not convinced it's a cold start issue or whether the immobiliser or steering column module is perhaps faulty or should I even try the spare key fob?
    Attached Thumbnails Attached Thumbnails Steering column lock defective!-dsc_0120[1]-jpg
    MY10.8 Icelandic Grey Passat 125TDI Highline DSG wagon with sunroof, ACC, MDI, RVC & auto tailgate (factory)
    Dec 2008
    Sydney/Canberra
    The locking module on the steering cloumn is about to die. Get it booked in and sorted out ASAP.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Sep 2010
    Yeap thx,
    Just had the steering column lock electronics replaced today (part# VW3C0905861J) by dealership + 2 bolts (part# VWN91217601).
    $554.25 repair all up.
    Jul 2010
    bracken ridge qld
    good to hear you got it sorted.i am getting the same message in my CC,hope to get it done for your price.trying to find someone other than dealership that can do it up here in brissy. no pattern with mine though,can happen anytime and so far no more than once in a day and sometimes only once or twice a week.
    cheers
    warrick
    2011 3CC 3.6 V6. 19X8 CADWELL RIMS, K & N FILTER, EXHAUST TIPS,DBA SLOTTED FRONT DISCS,ATE CERAMIC FRONT PADS.
    Dec 2008
    Sydney/Canberra
    The ESCL is tied in with the immobiliser, so dealership only, I'm afraid.
    '01 Beetle 2.0
    Jul 2010
    bracken ridge qld
    just had a quote from my local stealership for this same part,approx $1200! unbelievable.
    cheers
