Originally Posted by
Jemason
I did try putting the disc back in and you can hear it reading it but then nothing happens.
When I press eject after a few minutes, it comes out and says verifying navigation data but then nothing else after that. I have tried it three times but unfortunately no difference
It can see the maps if I put in an address manually but it is unable to route because it doesn't know where it is. No signal etc.
Is it outside when you are playing with it cos it wont find the satellites until it sits outside for a while.
It can take up to 15 mins to locate if the last time it was on was in Germany or similar.
Has it got the complete map or just the base map. Also if it has loaded say V6 map and you put it in again it wont reload it.
Get a copy of an older version and try that then upgrade to the latest. I have swapped back to V5 from V6 and back up again when the disc of V6 was faulty ( worked but data missing). It wouldnt however reinstall V6 over the bad version.
Worth trying but seems funny you have no other bits working Mine still had all the other going even when the map was sick.
Sounds like connection problems There is a connector in the roof below the sharkfin as well as someone on here found out when having satellite problems Have a read through the RNS firmware forums
