Hello to everyone,
I have got a VW Passat station wagon 4WD ( 4 wheel drive) of 05 /2006 ( it should be a 3C5 ),diesel 1968 TDI , power 103 kW, bmp motor type, manual transmission, FAP/DPF.
After turning on the amber light of the exhaust gas, the mechanic using his computer for diagnosis , told me that VAG-interface has detected a problem with the oxygen sensor and so it has to be replaced.
Initially, the VAG marked the error "oxygen lambda sensor" but now the oxy-sensor has been replaced and the same indicator light persist with a new error message on the same amber light (exhaust gas light): exhaust gas pressure sensor G450-Signal too High.
Soon, I will also change this sensor and I hope that this amber indicator stop light and everything resumes to normal operation !
In addition, the consumption of late have changed for the worse !
Thanks in advance to anyone who can give me more information and help on this matter ..
bye![]()
