Results 11 to 20 of 27
Thread: Smelly Airconditioer
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by Red Emperor View Post
    Also not all the water/condensation will make it out of the tube. That moisture over time will form mould on the condenser, which could produce a smell. I just had mine sanitised at the dealership, which is a 2 step thing which kills and removes the mould as well as make it smell purty. If the Glen20 don't work maybe look into that. Cost $123, may need doing every few years.
    Sounds like someone was a sucker for a pointless dealership upsell...
    Mar 2011
    Lidcombe, NSW
    On the note of air conditioner...
    Is it possible to have the recirculation button permanently on?
    i.e. no air to come in the car?
    I know I can just close each vent individually but that just takes more time and slightly inconvenient.
    Aug 2012
    Perth WA
    Quote Originally Posted by Rolls View Post
    On my B7, when you turn the recirc button on it remains on until I select otherwise. There is also an Auto (A) setting that is supposed to switch between fresh and recirc depending on pollution levels. Clever if it works
    Still waiting for my activated carbon impregnated Mann filter from UK.
    Oct 2014
    Parramatta
    thanks for your response.
    No i have not pulled the fan as yet. I will give that a go.
    yeah i have been more of a recirc guy but since i started noticing the smell & having googled/researched, i've been running ac with fresh air.
    thanks for your advise again. Appreciate it.
    Aug 2012
    Perth WA
    Just an update,
    It has taken a little longer for the cabin air filter to arrive from UK than ebay predicted, but I have finally swapped it out.
    Not very difficult to do except for where the foam covering lips under the back edge of the glove box.
    For those who are may change their own filter the original part number is Mann CUK 2939/1 with the activated carbon.
    I will report back latter whether the filter change removes the acrid smell.
    Sep 2014
    Yes the CARBONed one should remove the smell as per my experienced without using any spary or dedicated automotive air disinfectant
    I have but 3 from EBay (UK) as Ebay has the 20% promo from time to time which cost me around avg AUD$15 each inc postage . I generally swap them around 12 months as a preventive exercise before they get smelly.
    Rather than handing 50$+ to stealer each time
    Audi A4 B9(8W) AVANT Quattro 2.0 TFSI
    SOLD - Skoda 2012(MY12) 125 Tdi Superb Wagon, KESSY, Power tailgate, Panoramic Sunroof
    Aug 2012
    Perth WA
    The acrid smell seems to have gone.
    Surprised by how little muck was trapped by the cabin air filter to cause such a bad smell.
    Pacific Paradise QLD
    The reason it wont stay on recirculate is deliberate as if the air gets stuffy or a leaky exhaust gets into the cabin it can potentially put you to sleep or even kill you. Most modern cars only let you be on it for a short time and revert back to fresh .
    I have used this Einszett Air conditioner sanatizer and it works a treat.
    This guy in Murumbeena where I get all my detailing products from down here in Victoria sells it but I am sure you could find it at other stores.
    You put your air con on high activate the can and let the air con recirculate and the contents from the can filters through your system killing off all the smells and bacteria.
    Worked a treat in my Wife's AH Astra....
    https://www.carcareproducts.com.au/p...ma_cleaner_etu
    Erskineville, NSW
    I think it would work even better if you pulled the filter out first.
