All the ACs are the same basic design - cabin filter & glen20 should cure it but also make sure your plenum and lower parts of the front guards isn't full of leaves & that when running the AC there is a steady stream of water forming under the car (drain isn't blocked).
Cabin filter is common to all the Golfs, Audis, Skodas. Either of these should fit
Polin Filter Audi A3 TT Skoda Octavia VW Caddy Golf Jetta 1K2819653 Save $ | eBay
Cabin AIR Filter 2012 Volkswagen Passat 3C 125TDI Turbo Diesel 4 2 0L C | eBay
Sometimes you have to pull out the blower fan as that gets full of leaves & covered in black crud.
When you put the cabin filter in, slip one of those cardboard deodorisers in next to it
