Mine has had this from about 10k and now at 60k it hasn't got worse but it is still there.
I keep forgetting to mention it at services because I've modified my driving style to get around it.
Hi Guys,
I've got an MY10 R36 and since day one it has had a niggly issue. Under very light acceleration, particularly noticeable in stop-start traffic, there is a noticeable vibration/shudder that can be felt in the car. It does it both in reverse and forward and seems to get a bit worse once the car is warmed up. Its not violent, but definitely noticeable.
I have been back and forth to the dealer several times and most recently the dealer, under instruction from VW, arranged for the mechatronics unit to be replaced. This has been done - but the problem still remains. The dealer suggested I "give it 1000kms and see how it goes". Almost that many k's later - the problem still remains.
Has anyone else experienced this problem or has a theory as to what might be wrong? Is it a clutch issue, engine issue, transmission issue...? I'm pretty sure its not normal behaviour as I test drove other MY10 R36s and they were, from memory, perfectly smooth.
Me too! I've got 6K on the clock and I noticed it when I picked it up! Wasn't sure if it was me being too sensitive but with light acceleration it gave slight vibration at the start stop. Got the foreman to go for a drive with me when I had around 2K on the clock but we couldn't replicate it. Seems to have gone away now but it could be because I've gotten used to it??
BB R36 MY2010 Sedan ->Sunroof ->SatNav ->MDI ->DynaAudio -> LED Lights
RAY
do you guys experience these shudder after changing from or to R or D or from N?
maybe its the clutch engaging on stalling up.?
Yes we get this too with ours, particularly in reverse up steep inclines. More revs usually settles the vibration but doesn't seem to bring a huge amount more momentum... agree with Ron that it's probably clutch engagement related... question is, is this normal for the DSG's? I'm curious as this is my first DSG & I've been accepting it thus far as normal. Haven't really noticed it in forward progress though... perhaps because we use the autohold which jerks a bit when releasing anyway.
MY10 R36 Wagon Icelandic Grey
Jetta MY08 2.0FSI Reflex Silver
Sounds like the mechatronics issue - mine felt more like it was popping out of gear for a split second when moving off the line, then engaging - was really rough.
New mechatronics unit sorted it out.
to be honest had I not had a DSG previously I would have thought is was just the new fangled gearbox, and most journos do describe them as jerky at low speed.
I am no expert but thats what it sounds like.
Confirmed Global Warming Sceptic. No Longer a VW Owner -Loving my new 2011 Range Rover Sport - bought as VW unable to provide info on the new Toureg despite it being released overseas 12 mths ago. 2008 R36 Wagon, 2006 GTI and 2004 R32 - Gone. Sorry VW, you make great cars but until you improve your customers' experiences you will lose customers
Mine can be quite jerky when giving it a bootfull on take off, especially if its a hill. Is this the same sort of thing people are experiencing?
Gone...........R36 Icelandic Gray Wagon
Specialising in off-topic discussion
i would say this is quite normal. it is a manual box with twin clutch electronic controlled after all.
when i test drove M3 with similar box and it felt the same. Friends 997 turbo is also similar.
try reverse up a steep hill the box will stall even higher to avoid sudden clutch engagement.
