Bushes in your top links worn mate! and when new ones are fitted a big trap is to tighten them up when the vehicle is jacked up which is wrong. If you do that then the bushes are instantly under stress the minute you let the jack down! This also causes creaks.
Alba European
bump. my car is gettin worse lol the sqeeking is louder..
where would i get this part the cheapest??
you can buy top links X 4 for around $75 each mate. From VW they are about $ 250 !!!! Ive just done a set on an A4 same links. Have someone have a glance and a listen at it just to verify that it is them and if you are stuck you can send me some money and i can arrange a set for you. But like i said back a bit the other trick is in the fitting, you can fit them stressed and the will last no time and creak just as bad.
See how you go mate.
Alba European
