Results 1 to 10 of 15
Thread: Should I?
    May 2009
    Townsville,QLD
    Should I?
    Hi All,
    Am very close to purchasing a 2002 Passat GP,2.0turbo(good price for what seems a car in good nick)
    I believe this a good vehicle overall, but am a little concerned with pick up( have heard they are a little doughy) I am yet to drive it as I have to fly interstate to pick it up.
    Is this the case and if so what can I do to give it a 'little ' help?
    Thanks
    Jul 2007
    Sydney - the regressing city
    If you want to improve actual performance, a chip upgrade is the best bang for your buck...
    If it is just the acceleration feel, there is a device called "Sprintbooster" that improves the accelerator pedal response...
    May 2009
    Townsville,QLD
    Should I?
    Is there a particular chip that is better value/quality than another, and what sort of money are we talking?
    They're all much the same find out who you're local tuner is mate.
    edit put your location please.
    Aug 2006
    never knew b5.5 came with a 2L turbo
    Jul 2007
    Quote Originally Posted by BrettD View Post
    Do a google search - I remember there were some chip comparison tests done by some magazines...
    Bear in mind that not all brands are readily available here and you may also want to consider local aftersales support...
    Jul 2007
    Quote Originally Posted by BL33SU View Post
    Maybe it is a stroked motor?
    May 2009
    Townsville,QLD
    Should I?
    Have done some looking into the 'Sprintbooster', and the concesus seems to be that it isnt worth 'a pinch of s!#t'..
    Have also noticed on the net, so called 'Performance chips' worth about $20..what makes one better than another for $300???
    Anybody able to help me??....please
    Jul 2007
    As I mentioned earlier - sprintbooster is only for the feel - it does zilch to your car's actual performance...
    For those $20 ebay so-called chips, I understand they are just a resistor placed in the wiring to fool the ECU into thinking the ambient temperature is lower than it actually is, resulting in more fuel injected in the engine and thus improve performance.
    This may work in some cars but for VWs, the ECU has numerous sensor inputs and will adapt over time. My understanding when I spoke to my mechanic some time ago is that the ECU will adjust to the additional fuel over time and the car performance will be back to square one.
    Some of the more knowledgeable members here may be able to give you a better technical explanation...
    Use the search function Brett. This thread will be locked if any chip trolling occurs for reference.
