Not a factory option or dealer fit Chris, Sorry!
Anyone know if a reversing camera can be fitted/optioned to the R36 Sedan
Thanks Dermot
but there is this option....![]()
Retro fit the CC option.
That's what I am slooooowly working towards, but it's not cheap nor is it easy. I have the controller and most of the cabling, just need the camera / badge unit, and then will be able to work out what other cabling I need. But from there it's still a fairly big job to install.
Yeah - I certainly wouldn't want to try it myself!![]()
Would it be possible to retrofit the Touareg reverse camera (sits in the light assembly above the rear licence plate) and run the cables through to the stereo/display screen in the front????
Not sure if it is possible on the passat, may need to do some research into it.
It works on the tiguan (hence why i am going ahead with it) and the camera and parts should be picked up from ebay for about $50-$100.
Had a look over on vortex to see if anyone has done anything over there?
