Results 1 to 10 of 14
Thread: Sat Nav mods in Brisbane Can anyone help
    Pacific Paradise QLD
    Would like to get my Satnav firmware upgraded as it has 2840 in it which is pretty old.
    VW wont do it.
    Would also like to know 2 other things.
    Can the overspeed signal be altered to jump up in 1kph increments instead of 5kph.
    Also can electronic speedos be adjusted to be more accurate.
    My Passat is just over 3kph fast and the Polo is 7kph fast and is an absolute pain.
    I realise they are both legal but coming from a Landcruiser that was spot on at 100kph it drives me mad.
    Thanks in advance.
    Apr 2010
    Can't really adjust the speedo because it's out on purpose
    i.e. in my car there are 3 different speed readings that can be had:
    1. GPS - usually most accurate (you can view the GPS speed on your RNS510 via the secret menu)
    2. Hidden onboard speed used for odometer, etc (usually a few kph higher than GPS) - if you set cruise control, then erase your average speed in the MFD you'll see the average speed shows what the car believes to be the correct speed (a few kph lower than what the speedo shows you). You can also see this speed via the OBD2 diagnostic port if you have a device to read from it (i.e. a cheap bluetooth adapter from eBay and the Torque app on Android).
    3. The false speedo that you see on the MFD, out by a fair bit depending on your tyre size vs the max tyre size available in your range usually.
    RNS510 firmware is available for you to download via the big sticky thread in the Audio/Electronics forum here.
    Thanks but cant view via secret menu as mine doesnt have it Hence wish to update it.
    Would like to get someone who knows what they are doing to do it for me.
    To fix the Polo would need illegal tyres 40mm larger diameter.
    The overspeed alarm would be better with finer adjustment.
    Aug 2007
    you can adjust the accuracy of speedo in vcds.
    Apr 2010
    Doesn't that make your odometer inaccurate though?
    Yes I realise that but dont have any tools and limited wish to play around hence looking for someone to do it for a reasonable fee.
    Aug 2007
    no. the correction factor is an adaption value that you can enter with vcds. it just makes the speedo display closer to what the car is actually doing.. the car will still know the km travelled without a problem.
    Apr 2010
    Which module, byte and bit (or adaption channel) is it then?
    Sep 2011
    Melbourne,Vic
    Ryan, can you let me know how to access the secret menu on the RNS510?
    MY12.5 B7 V6 Passat wagon in Mocca Anthricite with Panoramic sunroof, SatNav, Driver Assistance & Visibility Package, Adaptive Cruise, Park Assist 2, Auto Tailgate,Tint, Towbar & RVC
    Apr 2010
    You need to have it enabled first (i.e. update the firmware - links in Audio/Electronics section)
    Then just hold down the Setup button for ~10 seconds. You'll see AM/FM after ~3 seconds, keep holding for another ~7 to get into the secret menu.
