Ok, I've finally made some progress. I did make some effort to try and remove the A-pillar trim but it just ended up being too hard. For anyone who's interested, there is a PDF with a bunch of trim removal instructions for the B6 her:
http://vwts.ru/body/b6/b6_70.pdf
I'm basically using Hillbilly's idea with some slight variations.
Required tools and parts:
- SF5125 Double mini blade fuse socket wire tap $4.95
- PS2003 Cigarette lighter inline socket $3.95
- Suitable additional mini fuse - probably no more than 5A since that's also the current limit of the above cigarette lighter socket.
- A short length of wire for the negative/earth connection
- Solder and soldering iron for soldering wires to the inline cigarette lighter socket
- Wire cutter to take the crimp connector off the end of the wire tap.
I've run the power for the dashcam down the driver's side A-pillar, on the windscreen side. It's very tight, but if you have some trim removal tools you can just them to jam the cable in so it will stay in place. At the bottom, I've tucked a bit of cable in under the bottom of the windscreen for a bit more stability, and then run the able along the gap between the white A-pillar trim and the dark dashboard trim. The cable just sits on the surface, but it's barely noticeable.
From there I tuck it in under the bottom of the A-pillar trim and down into the fusebox. It's easier to do if you remove the dark plastic centre A-pillar trim - with the fuse box open, use your fingers to gently pry the top of the inner edge towards you, and it should pop out easily. then gently free the trim piece from the rubber door seal, and lift upwards to remove.
Note that you will want to pull some cable through from the fuse box before doing the tucking around the windscreen, as the USB cable needs to run through a small gap behind a piece of plastic - you won't be able to fit the charger through if you go the other way.
In terms of power, in my MY10.5 R36, I found an ignition-powered fuse on the third row, third from the left - a 7.5A fuse that appears to power the parking sensors (I got a message on the radio to say "OPS inoperative" when I turned the ignition on with the fuse unplugged).
You will need the addtiional mini fuse if you are using the fuse power tap from Jaycar, because it piggybacks on an existing circuit - the existing fuse is reused for the existing circuit, and you need an additional fuse for the power tap circuit.
For the negative wire, I plan to loosen the screw that secures the top bracket of the fuse box and just jam the negative wire behind it.
My project still isn't quite complete - I need some fuses and some additonal wire to complete the job, but at least now the end is in sight.
Similar information here:
Dash Cam Power Supply installation.
